This one:
Street chip: Order this chip if you're using pump gas (91-94 octane). You can typically run 16-18psi boost in most cases (a little lower with 91oct). WOT (wide open throttle) fuel will be set up for the 16-18psi boost level and around 18 degrees timing. This chip can be used with alcohol injection. If you have alky injection, and you want the option of turning the alky off and running without it, then order a Street chip. This chip will not typically pass emissions testing. Torque converter locks at 45mph during cruising, and fan turn-on around 165* (unless otherwise specified). I do not set the torque converter to lock at WOT, as it typically causes too much knock and breakage. If you still want it to lock at WOT, you have to specifically tell me.
