T&D Roller Rockers - Shaft Mount - 1.65 ratio
Nasty Wendy
Perverted Lurker
I have a set of 1.65 ratio T&D shaft mounted roller rockers for sale. I also have the mount and hardware needed to run these on Champion 14 bolt heads.
I've included pics of them mocked up on stock iron heads. You can see the close up of the pedestal and where it will need to be clearanced if you plan on putting these on stock 8445 heads. Its not brain surgery, just a notch. The other pictures show the way they mount onto Champion 14 bolt aluminums. ALL the hardware needed is included in the sale. They mount to the Champion 8 bolt aluminums the same way as they mount to the stock irons except no clearancing would be needed.
Price is $460 for the rockers and all hardware + you pay actual shipping costs and fees. Yes I have paypal and yes you can pay 'friends and family' to avoid fees.
Price reduced $440 shipped rockers and all hardware. $400 shipped for just the rockers.
Willing to ship or bring to the Nats. If you don't need the hardware I'll do $400 for just the rockers.
Price reduced. $440 shipped for rockers and hardware or $400 shipped for just the rockers.
I will take the rockers for 400.00 shipped. The shaft clams for stock heads included?
Those actually go with the hardware. Don't confuse those with the shaft reinforcement pieces. The reinforcements are available through RJC. Those 'clams' go with the pedestals for the aluminum heads. They aren't going to give any reinforcement strengh as they are fairly thin. I believe they simply give the bolts that come with the pedestals a flat surface to tighten down on. Notice how they meet the pedestals on the aluminum head picture flush but they are gapped on the irons. They were made for those aluminum head pedestals.
I have RJC clamps for HD stock shafts, they will work with the T&Ds?
I do not know. A call to RJC should get you that answer. I haven't compared a heavy duty rocker shafts to a stock or T&D but I've always
ASSUMED they were the same OD with the 'heavy duty' coming in the form of thicker walls or solid construction.
Thanks, I sent you a PM. I will take the rockers shipped 400.00
hope you realize you cant just use them on either irons or alums
you can use stock rockers on irons or aluminums but when it comes to T+D rollers either they are for irons or they are for aluminums , they will bolt up to either head but they arent interchangeable
the alums use a different spacing and a different off set rocker
the shaft bridge allows a 14bolt head that was setup for scorpions to allow you to run shaft rockers , but they wont magically allow you to run a set of T+D rollers for irons on an aluminum head
