Lil Truck
I spend to much time here....
- Sep 26, 2002
hope you realize you cant just use them on either irons or alums
you can use stock rockers on irons or aluminums but when it comes to T+D rollers either they are for irons or they are for aluminums , they will bolt up to either head but they arent interchangeable
the alums use a different spacing and a different off set rocker
the shaft bridge allows a 14bolt head that was setup for scorpions to allow you to run shaft rockers , but they wont magically allow you to run a set of T+D rollers for irons on an aluminum head
I found the spacing problem ..... when I received them.
I was not aware of the off set on the rockers !!! That will probably cause push rod clearance problems even if the spacing is corrected?
