t-link not reading
mikeneedacar
when i try to connect my turbolink. it tells me no incoming data is recieving. what could my problem be.
Which version?
Are you using a USB converter?
If using V4, have you done the cable connection test?
Likely suspects would be:
* Physical connection to the car is loose
* If using old V2 stuff, parallel port problem with laptop
* If using USB converter, COM port not set up correctly
* V2, cable might be bad
* ECU quad driver bad
Look really closely at the the ALDL end of the "box". Make sure the pins are pushed up or bent (easy to do if things get a little sideways when plugging in).
Also, look at the ALDL port itself for the wires being pushed to the back of the plug.
