Sep 17, 2004 #1 G gndemon Member Joined Jan 10, 2002 Messages 65 I'm replacing the rubber seal no my t tops. Should the seal be glued in the track ?And there is this black goo in places is this factory or is this somebody's attempt to fix a leek
Oct 8, 2004 #2 D dirtrider04 New Member Joined Sep 17, 2004 Messages 5 sorry i dont have the answer to your question, but were do you you buy the replacment seals at?
Oct 8, 2004 #3 G gndemon Member Joined Jan 10, 2002 Messages 65 You can still get all the rubber seal threw the Buick dealership.
Oct 8, 2004 #4 Z zam70 ->ROGUE Joined Aug 6, 2001 Messages 2,731 Some glue them, some don't (I don't - I wouldn't use glue unless you have to and only in the places where needed) The "goo" needs to be there. It helps seal the seal to the body where there is no track to retain it.
