I picked up some street TA heads from Kenny D. (1.94" intake,1.60"exhaust and use the stock rocker arm setup) and I starting setting up the valve train last night with T&D roller rockers. After getting the correct push rod length I noticed an issue with the rollers on some of the rockers. Several had the edge of the roller in line with the edge of the valve stem and others placed the roller about 1/4 off the stem. If I reposition the washers on the T&D rocker arm shaft, I can get all the rollers to position on the edge of the stem but the push rods are now close to the head casting (they do not touch). I assume that TA repositioned the valve location slightly in order for the valves to fit. Any thoughts.
Jeff
Jeff
