TA Perf. Front Cover with adj. oil Psi
RUQWKNF27
I just bought one of these and you can adjust your oil PSI with it . I guess for the 450+ I spent it will be worth it to have 25lbs of oil psi @ idle.. Comes with new pump , blue printed an cleaned up passsages an ready to install.. Anyone else running one of theses???? ;)
Any info???? I can't find anything about it on their web site.
I have the T/A adjustable relief on both my cars but you need to understand that it only affects cruising oil pressure...not idle...idle pressure is controlled by bearing clearances...oil viscosity...oil pump gear end clearance...it's still a nice piece to have...
TurboDave,
If you download thier spring 2005 cataloge it has some info there.
Chuck
