ta33 from limit
Chatmanboy
Ok So I get the ta 33 and put it on. Now I have a problem n run high in rpm in first n second gear. Don't know y??? The only thing I did was delete the coolant lines from the passenger side to the TB. Anybody have a clue what the problem is?
The first thing to check is the vacuum line hoses for proper routing. This especially includes the waste gate actuator and the turbo compressor. Next check for vacuum leaks using choke cleaner around the turbo and vacuum lines. Also look to see if the turbo adapter is leaking as well. Brad
