Sep 25, 2019 #1 nickygn23 Active Member Joined Apr 10, 2011 Messages 962 Stock turbo or a TA49? Not sure..... Any help would be appreciated. Thanks Attachments 20190925_153505.jpg 607.4 KB · Views: 28 20190925_153457.jpg 748.8 KB · Views: 27 20190925_153501.jpg 807.5 KB · Views: 25
Sep 25, 2019 #2 Anthony P sharing knowledge with those who care to listen Joined Jan 24, 2007 Messages 1,280 TA49 uses stock housings...just bored for larger compressor & turbine wheels. look at turbo inlet. stock housing inlet is 2 inches while the 49's inlet is about 2.35 inches port matched to the machined 49 inlet bell that does not have the side port for the stock breather hose connection.
Sep 25, 2019 #3 Anthony P sharing knowledge with those who care to listen Joined Jan 24, 2007 Messages 1,280 also, stock compressor wheel is 7 blades (7 high + 7 low) while 49 compressor wheel is 6 blades (6 high + 6 low) this may help...pics worth a thousand words... http://www.gnttype.org/techarea/pictureguides/turboguide/turboguide.html
Sep 25, 2019 #4 nickygn23 Active Member Joined Apr 10, 2011 Messages 962 Thank you gentlemen. I'll check on it tomorrow. Thanks for the info.
