tach wire for wideband?
not sure why your wideband needs a tachometer signal..
but the tach signal is behind the a/c by the compressor lines
the green connector tapped to the harness
Second that,haven't come in contact with a wideband yet that needs a tach signal. What brand and model do you have.
its a dyno jet the tach signal is not required but it has a data log function that you can tie in the tach,boost,tps, pretty much everything
so from your opening postwhat does the tach signal have to do with wideband??
thanks for the info the harness for the wideband has add ons for data logging. bought it from a friend that used it in his lightning he went to big stuff 3 and doesn't need it anymore . I was going to install it today figured I would hook up as many features as I could
