Take a look at my fuel table.
NEARING
Is this ok or FU?
Car stumbles out of the blocks and likes to pop when down shifting to second at 50 mph.No ignition problems known.
I'am new to this stuff.
314/ 40.49.53.56.60.64.67.71.75.78.82.84.86.88.90.92
295/ 44.48.51.55.58.62.66.69.73.76.80.82.83.84.99.102
275/ 42.45.49.53.56.60.64.67.71.75.78.80.82.83.99.100
255/ 40.44.48.51.55.58.62.66.69.73.76.79.81.82.84.86
238/ 38.42.45.49.53.56.60.64.67.67.72.79.81.82.82.85
215/ 30.40.44.47.51.55.58.62.77.77.78.78.79.80.83.85
197/ 35.38.42.45.49.53.78.78.76.76.77.77.78.79.80.82
177/ 32.36.40.43.47.76.77.78.79.75.75.76.77.78.89.81
158/ 31.34.37.63.65.74.76.77.78.74.75.75.76.77.88.80
138/ 28.31.35.38.64.73.74.75.76.74.73.74.75.76.86.79
119/ 26.29.32.36.62.71.72.73.74.74.75.75.75.75.85.78
99/ 24.27.30.40.60.67.68.69.70.71.74.79.82.74.84.76
79/ 22.25.33.37.52.60.63.65.67.69.71.78.79.81.84.75
60/ 20.23.29.33.40.32.36.41.43.45.48.53.55.59.60.74
40/ 18.18.15.18.26.31.32.38.41.43.45.50.53.55.59.74
21/ 16.17.18 24.23.21.29.31.33.35.37.41.42.45.55.72
1/ 14.16.18.22.27.24.27.29.31.33.35.38.41.42.53.71
rpm 0 450 ect,ect.
see any screaming problems?
Thanks for any help.
I don't have any data logs as I have to use my sisters crapy old computer that has to run off the ac plug.
I can't get my new xp laptop to work with the fast, USB:mad:
MyTarget air fuel ratio vs rpm&Map
315 13.6/13.4/13.2/12.9/12.7/12.4/12.3/12.0/11.6/11.6-------
276 13.4/13.5/13.5/13.5/13.5/13.0/12.3/12.0/11.6/11.6-------
235 13.3/13.2/13.1/13.1/13.1/13.0/12.4/12.0/11.7/11.7------
197 13.0/13.0/13.0/13.0/13.0/13.0/12.5/12.2/11.8/11.8------
159 12.8/12.9/12.9/12.9/12.9/13.0/12.8/12.3/12.2/12.2------
119 12.6/12.7/12.8/12.9/12.9/12.8/12.8/12.5/12.5/12.5/12.5/
12.5/12.5/12.4/12.3/12.2
79 12.4/12.4/12.5/12.5/12.6/12.6/12.6/12.3/12.3/12.4/12.4/
12.4/12.4/12.4/12.5/12.5/
40 12.2/12.3/12.8/12.8.12.4/12.4/12.4/12.2/12.2/12.3/12.3/
12.3/12.4/12.4/12.5
1 12.0/12.1/12.1/12.2/12.2/12.3/12.1/12.1/12.1/12.2/12.3/
12.3/12.3/12.4/12.4/12.5
The last two or three values I guess do not matter as the car doesn't see those sort of rpm's.
:o I feel I'am in over my head!:(
Seems like much more info than a little scan tool on an ls1!:eek:
Think I will take her to a shop that has the time AND knows what they are doing.
I know a guy or two that know but they have thier own cars to work on and I don't like to bug people. :o
Fast timing map??
what's the timing map look like?? Looks lean in the middle..??
How much boost are you set for?
Suggest you get Lance or Craig to help U get the XP running B4 U blow it up!!;) ;) ;)
