tank location
sdteb
trying to get it like you
I am trying to find a location to put my alky tank...the problem is that under the headlights on both sides i have Passenger side is my PTE oil filter kit and on the drivers side i have the keene bell ram air kit.....thought about plugging off my coolant over flow and just using the current tank....any thoughts of this and where i could put the new 1 gallon tank i bought....
www.geocities.com/diyalky
is what my alky kit will be....
thanks to neil werner for the help on this one...
If your car has a 160 thermostat,you dont need a one gallon overflow. A little itty bitty teenie weenie :D container will do fine.
I like the factory overflow for alcohol. Just get a small container for the overflow and put it anywhere. A 16oz plastic coke bottle will work.
The last I did I went to the pull-a-part junkyard and got an overflow from a mazda..and mounted it to the fan shroud..zero change in engine temps. Or get a small overflow from an autoparts store and mount it between the battery and core support.
If your cars runs at 220 degrees..then you need more capacity in the overflow.
HTH
BTW..put a filter inline..
