Tank Strap brackets
Ok, today Iwas installing my walbro 340 kit from racetronix and all was going smooth. Pretty easy installation and not nearly as hard as i expected. But anyway we got ready to put the tank back up and positioned it and everything but as we tried to bolt in the straps(the ones toward the front with the 15mm bolts) we found that the little bracket with the bolt on the top was completly stripped! So my question is do you think any bolt with a locknut will work or do I need to get one of these brackets? If so any ideas as where i might be able to pick one up?
Matt
