quickstrike
- Jun 4, 2002
can someone expalin the relationship between the A/F ratio table and the VE table. What I mean is while running in lower RPMs in open loop I want to bring the A/F ratio up or down a little, I can obviously change the Base VE table. But according to the instructions even in open loop the ECU will use the Target A/F ratio table to calculate some portion of the Inj pulse width.
So my question is what is the realtionship to the 2 tables and can I change either one to get to my desired condition or is there a reason I should be doing it with only the VE table?
Is that confusing? I think I confused myself!
Randy
Randy
