turbojimmy
Supporting Member
- May 26, 2001
I checked the archives and couldn't find anything substantial. This is a follow-up question to a thread I hijacked in another section. In that thread, about a PT-61 turbo, the conversation turned to converters. The topic of RPM through the 1/4 came up and I posted a chart (because I'm a geek). The chart takes 2 Directscan recordings and plots MPH and RPM. In the chart I show various events from the DS log like shift points and TCC lockup.
The chart is here:
http://turbojimmy.4t.com/060604-2.htm
On the bottom left of the screen you can select Chart 3, Chart 2 or the Directscan data for each chart.
On each run the ECM calls for a TC lockup at 92 MPH. You can see it in the data. At 92 MPH, in 3rd gear, with 27" tires and a stock 3.42 rear, RPM should drop to around 4,000 RPM with a locked converter. The RPMs are not dropping at all really. The runs were recorded when the converter was new, trans is definitely not slipping (just had it apart actually and it looks fine inside).
On the street I can feel the converter lock up just fine.
Any ideas? I've been struggling to get faster than 115 MPH for a year-and-a-half now and I just can't do it. More boost, more timing, etc. - nothing helps. Now I'm starting to think I'm just running out of steam because I'm operating well beyond the peak RPM range. I just had the converter out of it, too. I wish I had thought of all this last week.
TIA,
Jim
The chart is here:
TIA,
Jim
