Tc Lockup With 93 Thrasher Chip
PaulRV6
What are the settings for the torque coverter to lock up with this chip? Both runs down the 1/4 resulted in non lockup. My other chip there was lockup in both 3rd/4th gear. Why?
Also what boost can I get away with on this chip?
Thanks for the help.
paul
The street chips don't lock at WOT, at least mine didn't. I just locked it up manually. Its set in the chip to lock or not.
Run as much boost as you can without getting knock. Every car is different but the Thrasher usually lets you run more than other chips. Low timing chip.
Unless you requested the forced TCC lockupat WOT (the "L" feature), the settings are much like stock. The sole exception being 51 MPH instead of 22 in the stock chip.
