I have my new 200 4r behind my 455 and it's working great. The car has 3.73 gears and drives great. I thought I wanted the lockup feature but now I'm changing my mind. On the highway it's great in 4th and locked up but in town the speed isn't high enough and the engine is lugging and bucking. I've read the use of the lockup is needed for heat but can I saftly drive this around in town ineither 3rd or 4th unlocked? I'll probably change to a non lockup this winter.
My next issue is the speedometer. I've ran the math and used the gear calcs. I have the orange 11 tooth governor gear and the 31 driven gear. When I checked it's speed with a gps it reads 50 when the speedo reads 60. Did I put the wrong set of gears in or can something else be wrong? Thanks for the help
