timdesu2000
- Aug 14, 2011
Hey all. Im having an issue with my tcc locking up in 2nd 3rd and 4th gear after the transmission is hot. Worse the hotter it is outside. Trans was recently freshened up and a new tcc solenoid was installed at the same time. Had the same problem before then trans was freshened up. I havent checked to see if Im getting a signal out of one of the switches yet to see if its fooling the ecm but it has a turbo tweak chip thats supposed to keep lock up off untill after 45 mph. It acts just like a sticking solenoid not bleeding off the tcc suppply fluid but with the same issue with two solenoids Im thinking its something else. Just wanted to see if anyone else has run across this?
Thanks,
Tim
Thanks,
Tim
