TCC Lockup/Solenoid
Sweet6
My ECM is showing the TCC is lcoked but it is not locked. I verifed that there is 12 volts going to the plug on the trans. I did an OHM test between A and D on the trans connector itself and did not get a reading. Any other tests? It seems like a bad solenoid. But wanted to make sure before I do anything.
TIA
just change it out. I did it for $75 with parts and mine works perfect now. Huge relief
Swapped mine out a few weeks ago while changing the filter. Wasnt locking as you described and I had verified voltage on tranny plug., def works now.
