tcc lockup
bigal
can someone tell me what the correct wiring is for manual lock up i know a is 12v, but bcd???. can i use 4th gear to ground the solenoid run a jumper from one of the pins to the ground pin.
Hmmm.
I just typed this very information here; the same time you posted your question. :)
The fourth gear switch on the 200-4R is normally closed. You can, however, get a normally open pressure switch from a 700-R4 application.
I'm not sure what you're working on there but you can usually achieve manual lock-up through the ALDL connector under the dash on a factory set up.
