TE60 and VDO Boost Gauge
TurboSlacker
SINISTR
TE60 with .63 Garrett exhaust. Wastegate hole has been enlarged and ported. Includes wastegate actuator. Appx 2000 miles. Excellent shape: tight shaft, no damage, no smoke. Great street turbo with quick spool-up and solid power.
$400 shipped
VDO 2-1/16" 30psi boost gauge. Works perfectly. Only minor issue is some of the black paint on the front bezel surround is gone. Can be easily painted if desired to make it perfect condition. Only selling because recently changed to a digital gauge.
$25 shipped
put me second on turbo pending some questions if the first guy dont take it thanks gil
What size is the wastegate hole? Did you run this with the stock stall converter?
Interested in purchasing VDO boost gauge. What else would I need to obtain for installation? And do you have instructions for install? Will you accept MO?
