You don't see my AFRs go between 11.53 to 10.37 and everywhere in between during my 2nd WOT run? I can see a steady decline or a steady incline, but not up and down back and forth during a wot run. What's wrong with this question? I'm not an expert tuner. I mean I know what's supposed to be happening, but this is a brand new Innovate LC2 so I'm unfamiliar with it.
The only place I see a variation is right after you lay the into it. Looks to me like your getting a 1-2 shift flare that makes afr's spike a little. Are you letting it shift on it's own or manual shifting?
Otherwise I don't see any major variations that would lead to concern. Once it's in high gear the reading is fairly stable. You will always see a slight variation in lower gears and during shifts.
