Tell me If this is a 10 second combo
434 11.1 compression, short block was from Ohio crankshaft so it was a little m block there 4340 h beam rods and 4340 crank , JE pistons, afr 235 heads, 2925 intake , 1000 hp from prosystems , 1 7 /8 headers , 3 inch exhaust, lunati 264 - 272@ 50 648 624 lift on a 109 lobe sep , baby cam for this motor idle at 900 , 4.11 gears , 4000 10 inch converter for nitrous from ptc , 28 x 10 slick, car weighed 3350 with me in it and ran 9.85 @ 137 , 60 ft was 1.39.
nice combo!
A turbo Buick isn't a n/a nova. Make some passes, and make sure you can launch it. It takes some different skillz to bring it up and hit it hard.
Sent from my HTC PH39100 using Tapatalk
Texas T I know exactly what you are talking about. 2 different animals for sure. The nova has the brute power from the get go while the buick is more of a tame to a wild animal feeling when the boost comes in. I'm gonna practice my launch and then get at him.
My car has no transbrake his car does. We both on 275 60 15 drag radials. I have him covered in the driving department. He seems to think turbo buicks are garbage because there 6 cylinders. Lol
Your buddy is correct; they are only six cylinders...the turbo makes it run like 12 cylinders.!!
Have fun and report back with the results.
Bob
If this is the same car we dynoed in Amsterdam, you will have no problem running mid, low tens. Your car made more power than mine, mine runs consistent 10.2-10.3. Phil.
