Bill_Ritter
Plays with Fire
- Aug 3, 2002
I went to the track for some test and tune last saturday.  when i began tuning the propain in, and increasing the boost, i lost a cylinder. the rear passenger side cylinder wall was completely washed down and had absolutely 0psi of compression when i tested it. so i squirted a little oil in there and fired it back up and everything was fine. My car has been set up exactly the same for the past 5 or 6 months, i havent changed the fuel pressure or anything. is it possible that the propane is what washed the wall down??? i cant see how it could do it since it is in a gas form when injected, and not a liquid. I dunno, mabey i was using too much propane or something, but i dont think so. I used the 86 jet at 50% duty cycle, and 39psi (static) fuel pressure. Have any of you guys had any problems similar to this?
