Try it again but this time use an extention and a hammer, rest and hold the extention on the block close to the sensor and lightly tap with the hammer, If still no knock then re-set the data-logger and try again but this time a little harder if you still see nothing then look at replacing the knock sensor, Always keep in mind it is a sensor and they CAN go bad.
