I'll also add to T-spool feedback. Both 34mm swaybars and all 4 alum drums came right away. Direct bolt-in w/no problems. Both my gn's thank you for the weight savings. Definetely more anti-sway in the front end compared to the stocker sway bar when you whip the wheel around at higher speeds. Money well spent. thanks T-spool
thanks for the fast service. The day you received the pay pal you shipped the test pipe. It got here exactly on time and as described. I hope to do more business with you again.
