here are the "after" picts of my front clip swap. I used the fiberglass headerpanel sold by G body parts.com and the fillers, new bezels, fiberglass kirban bumper, and new fasteners
Because I have a powerstroke IC i had to use some ol' fashioned ingenuity to mount the grille. They include hardware and instructions for mounting the grille from the back "wall" of the headerpanel. Since this had to be cut out to accomodate the IC I went to plan B which was to use the space covered by the bezels on the inside end and fab up a bracket on each end that I then made into an L shape. I then drilled a hole on each end of the grille edge to accomodate a bolt which I had to make a small amount of forward clearance for on the header panel. It came out alot better than I thought it would its basically invisible. I took a close up pic so you can see where the bolt is on the edge of the grille. Im just getting the car ready for painting in the near future.
I included one of my ugly mug after all day of working on the car on about 4 hours of sleep and a hang over
