spross86
- Jan 6, 2015
well I am stumped with this issue? when I disconnect the battery over night and the car is cold it runs good
if I take it out for a test drive after about ten min. of driving it starts stumbling , surging , dies at idle and in and out of gear? when I get it up to speed say 45mph it runs ok but if I try to accelerate it stumbles?
1986
30 over block
36lbs injectors with TT chip
TE 49
everything else is bone stock
new tps
new wires , plugs
new ECM
new Coil pack and ignition mod.
new MAF (3)
new 3 Bar
new vac. lines all of them
new fuel pump with hot wire kit
fuel pressure 39 vac on 44 vac off. rises under boost
cleaned TB
cleaned all grounds and installed more
I attached a snap shot from Power Logger File
I don't no what else to try!
1986
30 over block
TE 49
new tps
new wires , plugs
new ECM
new MAF (3)
new 3 Bar
cleaned TB
