lmao Phil is such a rebel
Dude you are probably not gonna wrinkle yours unless it is cutting some really nasty 60 fts.
Let's put it this way, if you are fast enough to wrinkle the fender, you need to have a cage and probably some chassis work also.
True.
When you do it, use at least 1/8 inch plate. Skip around when welding. Don't weld more than 1/2" at a time. And brace the frame at the proper height before cutting it up.
