Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Prior to starting; I know very, VERY little about electronics and these are a few honest questions. The question going around in my mind is; "What would be the capabilities of the perfect ECM for a TR and how close did anyone ever get without a Formula 1 Budget?".
As a result of my question, I composed a list of few “Nice to” variables. It is realized that there are MANY more variables, but again, my limited understanding prevents me from even asking the questions. Stock or modified ECM with all or most of the following;
· Aftermarket chip (Setting for mileage, Emissions, Power)
· True sequential injection for each cylinder
· Injection timing adjustable (Start or End)
· Adjustable pulse width for each cylinder (Cylinder specific injection)
· Wide-band feedback Controlled (Injection based on load/RPM and desired fuel ratio)
· ECM Controlled Alky injection through MAP (inject ECM controlled alky like the injectors do)
· Adjustable Spark advance for each cylinder (Back cylinders may require less advance)
· MAF upgrade in chip (An upgrade in the ECM that allows for a predetermined MAF upgrade)
Alternatively, ....... Can one get an ECM like out of a 2004 6 cyl turbo car (I know there are not too many around) and make it work through a adapter into the existing harness an a custom chip programming? Am I dreaming?![Roll Eyes :rolleyes: :rolleyes:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f644.png)
