The right deatured?
rb68rr
I was in Ace Hardware the other day and saw this 1 gal. can. It read:
Denatured
Alchohol
Pure
Contains ethanol CAS#64-17-5, methanol CAS#67-56-1, methyl isobutyl ketone CAS# 108-10-1, ethyl acetate CAS#141-78-6, rubber solvent CAS#64742-89-8, water CAS#7732-18-5.
Is this the denatured that most people run with their SMC alky kits? If not, which one is it? Thanks, R.B.
Yeah....I bet that's OK.
I get mine at Sherwin Williams. The majority of the mix will be ethanol (grain alcohol / everclear)...They put just enough methanol in it to make it undrinkable.
If it says Denatured or camp stove fuel....you've got the right one.
FYI...the denatured is a little easier to tune with, but adding water to the mix will actually get you better knock control.
Good Luck,
John
