updated parts list from shop clean up
I want #67...... please sent pics thanks
here is the pic, nevermind the barney purple its just paint and should come off.
Hi:
I need the passenger rear wheel well molding and the passenger taillight assembly.
Thank you,
Dick Lynch
Here is a updated list still have alot to ad, serious buyers only. pic upon request, paypal check or m/o. shiping extra. Thanks
Greg
GRAND NATIONAL REGAL PARTS
INTERIOR
#5 HVAC VENT BOX MOUNTS TO BULKHEAD BEHIND DASH $20 O/H 2 SHOP ATTIC
#7 LEFT REAR LOWER SAIL PANEL GREY/BLACK $15 SHOP ATTIC PIC
#8 LEFT UPPER REAR SAIL PANEL GREY/BLACK $10 SHOP ATTIC PIC
#9 RIGHT UPPER REAR SAIL PANEL GREY/BLACK $10 SHOP ATTIC PIC
#10 RIGHT LOWER REAR SAIL PANEL GRE/BLACK $15 SHOP ATTIC PIC
#13 REAR METAL HEADLINER TRIM $10 O/H 2 SHOP ATTIC
#26 POWERMASTER BRAKE PEDAL ASSY $30 O/H 2 BOX 1 PIC
#27 GREY UPPER REAR SAIL PANELS $40 PR SHOP PIC
#29 DASH HARNESS RADIO PLUG CUT 1 SPLICE $150 BOX 1
#35 GREY AND BLACK FRONT BUCKET SEAT BELT BUCKLE ASSY $60 PR BOX 3 PIC
#37 LOWER DOOR PANEL SEALS $10 PR BOX 1 PIC
#47 PASSENGER UNDER DASH COVER $10 O/H 3 BOX 1/2
#48 SEAT BELT TENSIONERS 2 PAIR O/H $10 EA BOX 2
#49 DOOR JAM VENT $10 BOX 2
#50 DRIVERS SEATBELT GUIDE GREY $10 BOX 2
#51 REAR TTOP HEADLINER TRIM GREY 2pcs $30 BOX 2
#52 DOOR PANEL PULL TRIM FRONT AND REAT $20 EA BOX 3 PIC
#53 PASSENGER KICK PANEL 3 PIECES GREY 2 O/H $30 BOX 2/5 PIC
#54 DASH CLUSTER DASH PAD GREY $30 BOX 2 PIC
#55 VACUUM BRAKE PEDAL ASSY $30 BOX 4 PIC
#56 RADIO BEZEL NICE NO BROKEN TABS 2 O/H $15 BOX 2
#58 PASSENGER LOWER PIVOT SIDE SEAT TRIM GREY $10 BOX 2
#59 TTYPE HORN PAD WITH HORN PLATE BURGANDY $10 BOX 2
#61 INSTRUMENT CLUSTER MOUNTING BRACKET $50 BOX 3
#62 ACCELERATOR PEDAL WITH HARDWARE $20 BOX 3
#68 BURGANDY SUN VISORS NO MIRRORS, REDONE $50 PR BOX 3 PIC
#69 BURGANDY REAR STEERING WHEEL COVER $10 BOX 3
#70 GLOVE BOX INSERT $10 BOX 3
#71 HVAC CONTROL HEAD COMPLETE MANUAL $40 BOX 3
#72 HVAC CONTROL HEAD COMPLETE MANUAL $40 BOX 3
#74 LARGE GREY TTOP CENTER TRIM NEEDS PAINT $25 BOX 3
#75 PASSENGER B PILLAR GREY FOR TTOP $15 BOX 3
#89 HVAC BLEND DOOR CABLE $10 BOX 2
#90 GLOVE BOX LATCH/LIGHT SWITCH $5 BOX 2
#94 GN DASH PLAQUE (1) $75 EA BOX 1 PIC
#96 ARM RESTS DOOR PANEL GREY PAIR 2 O/H $30PR BOX 3
#97 NOS DOME LIGHT LENSE ROUND (2) $10EA BOX 3
#103 DASH PANEL GREY BARE $150 ATTIC PIC
#107 INSTRUMENT CLUSTER ANALOG (FOR PARTS) $15 BOX 3 PIC
#113 DOOR SILL PLATES 6 O/H $12EA ATTIC
117 GREY GN STEERING WHEEL CORE $20 BOX 5 PIC
#124 KICK PANEL DRIVERS GREY $15 BOX 5 PIC
#126 REAR SPEAKER HANGERS $10PR BOX 5 PIC
#128 B PILLAR TRIM GREY DRIVER SIDE HARDTOP OR TTOP $25 BOX 5 PIC
#129 COVER REAR STEERING WHEEL GREY $10 BOX 5
#130 A PILLAR TRIM GREY DRIVER SIDE NO DAMAGE HT OR TTOP $25 BOX 5 PIC
#133 UNDER DASH VENT GREY AND BURGANDY DRIVERS SIDE $25 BOX 5 PIC
#135 GREY LOWER SAIL PANELS $50 PAIR UHAUL PIC
#137 REAR SPEAKER PACKAGE TRAY BOARD GREY $20 ATTIC PIC
#138 SAIL PANELS REAR LOWER BURGANDY $40 PR BOX 5 PIC
#139 BURGANDY DASH EDGE TRIM $10 PR BOX 5 PIC
#140 HEADLINER METAL TRIM GREY BURGANDY OR BARE METAL $10 EA ATTIC
#142 A PILLAR TRIM BURGANDY NO DAMAGE $30 PR BOX 5 PIC
ENGINE COMPARTMENT
PART DESCRIPTION PRICE PART LOCATION
#2 84-87 RADIATOR CORE SUPPORT $75 SHOP ATTIC PIC 2 O/H
#11 MAIN HVAC HOUSING ASSY FOR BULKHEAD $75 SHOP ATTIC
#25 HVAC BOX ENGINE COMPARTMENT SCREEN $30 BOX 3
#30 INNERCOOLER FAN $15 BOX 1
#31 A/C CONDENSOR $20 SHOP ATTIC
#32 HEADER PANEL TOP BRACE $15 O/H 2 BOX 1 PIC
#33 TRANSMISSION INSPECTIO0N COVER $15 BOX 4
#34 BLOWER MOTOR WHEEL $5 O/H 3 BOX 1
#36 HOOD HINGES O/H 2 PR $15 PR BOX 1
#38 84-85 HOOD TURBO HEAT SHIELD $10 O/H 2 BOX 1
#39 A/C DRYER $10 BOX 1
#41 WIPER ARM LINKAGE $20 BOX 4
#45 POWERMASTER COMPLETE INOP MOTOR CLICKS $80 BOX 4
#57 CHARCOAL CANISTER PART # 7085935-HU $15 BOX 3 PIC
#60 ACCELERATOR CABLE $20 BOX 2 PIC
#64 COOLANT OVERFLOW BOTTLE WITH CAP $15 BOX 2
#65 CRUISE CONTROL CABLE $10 BOX 2
#66 CRUISE CABLE SERVO BRACKET $10 BOX 2
#67 HOOD RELEASE CABLE $10 BOX 2
#73 84 85 TURBO MOUNTING BRACKET $30 BOX 4 PIC
#82 UPPER SPEEDO CABLE $10 BOX 2
#85 HOTAIR TURBO HVAC BOX HEAT SHIELD $20 BOX 4
#86 WASHER BOTTLE WITH CAP 2 O/H $10 BOX 2
#88 DRIVERS INNER FENDER WELL TIRE RUB HOLE $25 SHOP ATTIC
#91 FRONT RAD SUPPORT CROSS BRACE 2PCS $10 BOX 4
#92 84-87 DRIVER HEADER CLEAN PIECE DOES HAVE CRACK $35 BOX 4 PIC
#93 20 BOLT OIL PAN VERY CLEAN NO RUST OR DENTS $50 BOX 5 PIC
#98 CONNECTING RODS TURBO 2 DOT STD BEARING $75 ATTIC PIC
#105 HVAC BOX TURBO HEAT SHIELD 84-85 $13 BOX 4 PIC
#106 TURBO J BRACKET $50 BOX 4
#108 WIPER ARMS BLACK PAIR $30 BOX 3
#111 SEAL COWL HOOD $15 BOX 3
#115 SPEEDO CABLE UPPER $20 BOX 3
#119 COOLANT OVERFLOW BOTTLE 84-85 W/CAP $15 BOX 3
#120 ELECTRIC RADIATOR FAN STOCK 1 O/H $50 ATTIC
#121 FLEXPLATE $25 BOX4
#123 86-87 A/C LINES $100 TRUNK
#141 STEERING SHAFT WITH PLASTIC SHROUD $30 BOX 4 PIC
Can u send me a pic of #38 84-85 HOOD TURBO HEAT SHIELD $10 O/H 2 BOX 1 I will most likely buy it thanks
