Turbo6Smackdown
- Dec 31, 2005
I did a search, but actually found nothing. Maybe I just suck. Oh well, anyhow, I just had my "LT1" valve springs checked, to see if they didnt have any crazy pressure (after reading richard clarks zddp thread, i started getting nervous about this install. if i wiped a lobe, Id be devastated)
I took em to Automotive Machine (a local shop with a decent buick reputation) and had em check em. I checked with you guys first, to see about installed height, and you guys said pretty much 1.72. So I walk in, tell em what I need, and he asks "What kinda pressure are you lookin for on these"... (I said "I think theyre 105's, but im not sure)
That kinda made me wonder. Why do you need to know that I thought. Is he going to not measure them, and just tell me what I want to hear after that? So after picking them up, he said "they were all +/- 5 lbs of what you specified." I see... Then, I come back here to re-read some posts, and now I keep seeing more and more "dont go too heavy, or youre going to wipe a lobe"... So is +/- 5 pounds on a 105 pound spring ok?
(the guy at the shop recommended around 90 pounds when I asked him)
Also, they have the little damper springs on the inside. Do I keep these? And whats this 'cup' I keep hearing. Some guys say they used em, some say they didnt. Do you use this 'cup' to gain a few more pounds of pressure? Or am I misinterpreting this. If these are indeed 100-105 pound springs, is there anything I can do to make em seat with a little less pressure?
Not use the cups or dampers? Tell me what to do. I plan on doing my timing chain, and changing the oil with zddp as well. What do you guys recommend?
