Ok, I get a little extra time and things get out of hand around here ![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
I'm developing a simple(cheap) protection system for use in conjunction with the alcohol kits.
Initial thought process is pressure switch on pump outlet. Problem is if nozzle were to be clogged, all the pressure in the world would be available and the protection wouldnt be there.
Then I thought, possible current tracking.. in other words see how much the pump is pulling and if the current is within range, leave things as is. Problem is current can vary from vehicle to vehicle. And not really an easy way. Plus the plugged nozzle syndrome will still exist.
Then.. flow meter.. this would be the E-ticket. Get a chemically resistant flow device that outputs pulses as the liquid flows through it. Problem I have found is the meters will be upwards of 150+ plus fittings/electronics/interfacing.
Finally what I've been using has been my ATS sensor relocated into my plenum. Thats the sensor located by the air filter on the GN. Ive been tracking intake air temps with that device now for the last year. So here's my thoughts. Please chime in.. make this happen.
Run a conditional switch, so that when the alky pump is energized, the circuit activates. Then have a wire sense the reading of the sensor and if the reading goes past a certain point.. trigger a relay that fires a warning device.
Elaborated a little further. I'm going to use an autometer pencil shift light tied into the relay. I'll set the threshold like on my own car at 110 degrees. If the temps inside the intake climb past 110 degree's.. it fires the light.. and can also control a boost solenoid or other protection of your choosing. Audible alert, lamp, etc...
Issues.. must drill a pretty big hole into the plenum to mount the sensor. Its 3/8 pipe NPT thread. Other option is to mount sensor after the nozzle. There are thermistors that are really small that may be slipped in under the pressure hoses. The neat thing about the GM sensor.. the thing works flawless.
If the alky system ever stopped spraying for whatever reason, the temps would climb fast and trigger the device.
Now the issue is to make the system bare bones(cheap) or add electonics like a bar graph to show temps. Bare bones, would set it, stick it in the glove box.. forget about it. Reasoning.. think we have enough to look at while going down the track. And a DS can record the sensors operations through the MAT input.
Thoughts? Opinions? Ideas?
Thanks.
Thanks.
