i just purchased a thrasher street chip and i'm haveing problems the car won't idle right i set the fuel pressure to 45 and the car idles terrible when i put it in gear the car wants to cut out and when i step on the gas. i have tried to adj the tps and iac according to the procedure on gnttype.org. the 02 sensor reads almost a flatline lean at idle. now if i can keep the car running on the road the car runs great off idle and at WOT the car screems and it runns great but the idle sucks and i don't know how else to adj it . when i try to adj iac and tps the reading are all over the place and keep changing (iac will be 05 then 25 then 00) is this normal. i mean i love the top end power the chip has but i can't deal with the idle.
anyhelp fellas?????? thanks
