MY THIRD BRAKE LIGHT IS NOT WORKING ON MY GN. I CHECKED THE BULB AND REPLACED WITH NEW ONE. ORIGINAL BULB WAS GOOD.
I THEN WENT TO THE TRUNK AREA AND FOUND THE POWER LEAD. THERE IS NO POWER COMMING OUT OF THE LEAD? FOLLOWED WIRE UNDER TAIL LIGHTS AND INTO HARNESS AND ALL APPEARS GOOD TO THE EYE.
I DIDNT WANT TO TAKE EVERYTHING APART AND THOUGHT TO CHECK WITH THE BOARD TO SEE IF THEY HAVE ENCOUNTERED THE SAME PROBLEM AND TELL ME WHERE TO LOOK.
NOTE: WHEN POWER IS PUT TO THE CIRCUIT THE BRAKE LIGHT WORKS.
