- Aug 24, 2012
I just deleted the stock passenger side breather tube from my new to me TR. It's a 120k mile car, so of course it has plenty of oil in the intercooler and up pipe. The throttle body has a thin coat in front of the butterfly and a much thicker 'varnish' behind it. I'm in the process of upgrading the turbo, intercooler, and piping so I have those parts covered. That leaves the IAC and throttle body. When I cleaned the throttle body/intake/IAC on one of my newer naturally aspirated cars, I sprayed everything really good with TB cleaner and scrubbed it with a brush until the carbon buildup was gone. I then started it and let it run until it idled smoothly and stopped smoking. I want to make sure this same process will work with my Limited before I do it. I've read some guys here use the throttle body cleaner while the engine is running. Is there a special reason for this? Which is the best way?
