Throttle body gasket
85begalttype
just a v6
I removed my hot air throttle body and there is no gasket between tb and turbo. is there supposed to be one?
i think so i have one there now i know some of the guys here use an o ring at that connection someone will jump in but also do a search on throttle body in this hot air section ull find ur answer
Yes it should have a gasket...
It is felpro # 60654 I believe. that is what came up when I looked it up at work (Autozone). When you take the tb the gasket pretty much always tears because they turbo and tb kinda grow together. I checked for a vacuum leak there one time and had a small leak so I took the tb off and added a smear coat of silicone and that fixed the problem.
God luck,
Jerry jr.
