time to burn it
hey crazy-
what mode do you have turbo link in?normal or aldl?
Ive been running it in aldl mode, it seems to take the rpms up a little more in aldl mode tho . I a little new with it i just got it the other day.
how many people on here have the v2 set up i could really use the help. Or maybe no body like me;)
do NOT run your car in aldl mode.it is for diagnostics only.
put it in normal mode and go see what it does.
later,sean
oK no ALDL mode.:eek: I would try it again but my tranny is down now and i need a gasket for it.
Ive been trying to get the vac line route for 4 months now and no one will step up, there has to be some where i can get a picture of this set up. :(
help
Come on guys with the v2 vac set up , i'll even buy a drawing from you if i have to but i gotta get this thing fixed soon.:(
hey crazy,which way do you have your check valve facing?if it has an arrow on it it should point away from the vacuum block.this would allow the block to be under vacuum during normal operation but not allow boost through under wot.
I think thats the way that i have it now, i just put the old y fitting back in to see if it helps i had a t there before. the only thing i can think is that the one way valve is to hard for the vac to open , maybe i should try a new one.
I CANT START THE CAR NOW TELL I GET THE TRANS FIXED.:( :mad:
Any one need a flower pot for there yard, never mind the tranny leaks fuild now so that would not work to good. probley kill the flowers.:(
