Dreamcar86
- Apr 13, 2006
Just about to finish up on an engine rebuild and found a crack in the original front timing cover as well as chewed up oil pump housing.
Question is: on the factory cover the seal was installed from the inside. My aftermarket cover is set up to install the seal from the outside. Where do you find a seal that will work? Went to autozone and the diameter is too large.
