Timing chain replacement
84GNTTYPE
Senior Member
My car rolled over to 100,000 miles over the summer.
I'd like to replace the stock timing chain and am wondering if anyone makes a kit with the necessary gaskets, chain, gears, etc all in one.
Also, is there anything else I should replace while I'm down there?
Thanks,
John
I don't know of an "all in one" kit, SE turbo had the best deal on a roller chain and a gasket set can be had at any parts store. Would not be a bad idea to replace or at least thoroughly clean the oil pump pickup (still available through GM). The oil pan has to come off anyway so a rear main (neoprene-not rope) seal couldn't hurt. Also get the cam button with the roller bearing on the end of it.
I'd like to replace the stock timing chain and am wondering if anyone makes a kit with the necessary gaskets, chain, gears, etc all in one. Also, is there anything else I should replace while I'm down there? .....
While the cars are a bit different in the accessories, this is a good thread.
You may end up replacing more ……… like in this thread. :biggrin:
Excellent documentation!
http://www.turbobuick.com/forums/showthread.php?t=166980
FWIW ...... I removed the front cover without removing the oil pan, but not a bad idea to remove and clean/check.
I find it incredibly difficult to remove the timing cover without getting coolant in the pan. I had the drain plug out, and had previously drained the hoses and water pump as well as humanly possible, but when I decided to tear the pan off anyway, I noticed that there was a good 4-5 ounces of coolant in the pan! If I hadn't taken the pan off, I would have sworn there was no coolant in it, because i hadn't seen any go in, but it still seeped in. About the only way I can think of would be to pull the water pump off and stick a tube in the block passages and pump it out with something, and that might not even be perfect. just my opinion.
