C
Cakes
Guest
I have been dealing with a knocking/slapping when my motor has been fully warm. Many people have told me my bearings could be the culprit, which I am not ruling out, but I checked them when I did my rear main, with the mechanic at my side, and they seemed normal for an engine with 40k on it. I have no noise at idle but when the engine is free revved from 2000-2500 it will make a slapping/knocking noise and then as rpms go higher the noise goes away. I know the previous owner replaced the timing chain with a double roller from ATR(Cloyes) and I am fairly certain that chain is for the stock line bore(they do make one for .005 and .010 line bore) The reason I say for a standard one is because the engine was rebuilt my GM (under warrantee) and I dont know if the engine was aligned bored or not. Also on the ivoice from ATR, I did not see a new cam button purcahse so I am assuming he used theold stock one. I have been trying to figure out where the noise has been coming from using a stethoscope and I think I have pinpointed it to the timing cover. A bearing just doesnt make sense to be because it only does it when its warm and at a particular rpm...even holding steady at say 2500 and then if I blip the throttle the noise will occur and then go away. Any ideas/help/insight is greatly appreciated! Thanks for your time!
