You can add more alky and take away the fueling through the injectorsif you want. However, generally if the car has a good AFR and starts knocking you have the timing too aggressive. I generally like to just leave the timing slightly lower and turn the boost up. I have had more engine failures with lots of timing than with lots of boost. Drew
