The waste spark actually makes it brighter - you get one flash per engine revolution instead of one flash per two revolutions, and the flashes will happen at the right time so if you set your dfi to zero degrees advance then the line on the balancer and the zero line on the tab should line up. If you have a delay timing light then you will need to tell it waste spark or divide the reading by two. In other words, using my friend's SnapOn delay light when I set the timing light knob so the display reads 40 degrees and my chip is commanding 20 degrees of advance, the timing marks are lined up.
