timing verus boost
Cleaner13
The Cleaner
ok just wondering how this works
is more boost available with less timing or more timing?
how does these compare?
what are the benefits and losses of timing advance or retard?
I am getting my cusom chip changed at some point soon since I will be running alky dual setup, an LS1 MAF and translator(regular) I heard you could run a race chip with your alky set up
anyone have a recommendation as too what kind of timing I should ask to be run and what air/fuel ratio, mine in the chip is 13.5:1
thanks guys
I also have a bleeder valve set up
one other question
if you run a bleeder valve setup couldnt you theoretically run a race chip as long as you have the boost down?
thanks alot guys
