turboG
never enough....
- Sep 27, 2001
Will higher timing in the lower rpm range help the turbo to spool faster? To the best of my memory ......several years back one of the vendors had a variable timing chip and used a 3 bar map sensor to sense boost. In lower rpm's and no boost, the timing would be higher and as boost/rpm's increased the timing would ramp down. The reason given for this was to aid in spool up. Is this correct or am I dreaming?
