Apr 14, 2002 #1 R rightonjoe Guest I need a little help here , at least a starting point to work from.
Apr 14, 2002 #2 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 What kind of car do you have? If it's a GN, how much boost and what octane?
Apr 14, 2002 #3 R rightonjoe Guest timing Chevy 406, cam is 250 and 260 at .050 ,mini ram intake and the usually performance parts thanks Joe
Apr 14, 2002 #4 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 We run 38 on the 355 I tuned (EFI 11 car, best runof 10.87). I would start with 36
Apr 14, 2002 #5 R rightonjoe Guest timing Is the inital timing( 6 degrees in my application) included in the spark map table or excluded thanks JOE
Apr 14, 2002 #6 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 Put a timing light on it. It should be inclued. I ASSume it's a DFI car?
Apr 14, 2002 #7 R REDS HOT AIR Buick Tweaker Joined May 24, 2001 Messages 3,433 400 sb's like less timing than a 350 motor were most 350 motors like timing in the 36-38 range i have found the 400 motors to like 32-34 max.
