timming
HGturboT
HomeGrownPerformanceLV
need to set it and forgot (been a while) i have the cam tool but where do i set the crank
Tming is controled solely by the chip based on input paramters. It is NON user adjustable (Most chips nowadays you can adjust the timing but not really in a mechanical way)
Timing will vary as well, for example (Example only!):
Idle - 35 deg
Cruising - 40 deg
Full boost/load - 21 deg (first gear)
Full boost/load - 20 deg (second/ third gear)
All a function of the chip/program.
