First table is spark, multiply by .352 to see it in degrees.
Second table is VE.
At a glance it looks very different then what your used too, but the shape of the tables, and the way the timing ramps out, and VE increases are the areas of interest.
Part of the secret is keeping any excessive heat off the piston crwon when not in PE. So a lil rich with a few degrees less timing help. It also keeps some heat out of the oil and reduces blow by slightly. Any one item by itself is no biggy, but when you add up the details it all gets important.
The AE stuff should rather quickly fall into place once you have the timing and VE correct. IMO, anyway.
; 3 BAR 45 75 100 125 150 175 200 225 250 275 300
FCB 61,61,61,61,45,34,28,28,28,28,28,28,28,17,17,17,17 ; 600
FCB 61,61,61,57,45,34,28,28,28,28,28,28,28,17,17,17,17 ; 800
FCB 42,42,61,57,52,48,31,28,28,26,26,26,21,21,17,17,17 ; 1000
FCB 32,42,68,68,63,48,37,28,28,26,26,26,21,21,17,17,17 ; 1200
FCB 32,42,71,71,68,61,60,48,28,26,26,26,21,21,17,17,17 ; 1400
FCB 32,42,74,74,68,63,48,48,48,33,31,26,23,23,23,23,23 ; 1600
FCB 32,42,74,74,68,63,51,48,48,33,31,28,28,26,26,26,26 ; 2000
FCB 32,42,74,74,68,63,58,53,51,43,31,28,25,25,25,23,23 ; 2400
FCB 32,42,74,74,68,68,63,57,54,43,38,38,34,34,34,34,34 ; 2800
FCB 32,42,74,74,68,68,63,62,54,51,49,46,46,42,42,42,42 ; 3200
FCB 32,42,74,74,68,68,68,68,60,54,54,48,48,48,46,46,46 ; 3600
FCB 32,42,68,68,68,68,68,68,65,65,63,57,57,51,51,51,51 ; 4000
FCB 32,42,68,68,68,68,68,68,65,65,63,57,57,51,51,51,51 ; 4400
FCB 32,42,68,68,68,68,68,68,65,65,63,57,57,51,51,51,51 ; 4800
FCB100,100,100,100,100,100,100,100,105,105,110,130,130,130,140,140,150 ; 400 RPM
FCB100,100,100,100,100,100,100,100,100,100,110,130,140,140,150,150,150 ; 600
FCB100,100,100,100,100,100,100,100,100,105,110,130,140,140,150,150,160 ; 800
FCB30, ,30,100,115,115,115,110,115,110,115,145,150,155,160,160,170 ; 1000
FCB30, 30, 125,125,130,135,140,145,155,155,160,165,170,170,170 ; 1200
FCB 30, 30,100,130,135,135,140,145,150,155,165,170,175,180,190,190,200 ; 1400
FCB 30, 30,100,130,135,140,145,145,150,155,165,170,180,185,190,210,220 ; 1600
FCB 30, 30,100,135,140,150,150,155,155,160,165,170,180,185,190,210,220 ; 1800
FCB 30, 30,100,135,140,150,155,155,155,160,165,175,180,190,190,210,220 ; 2000
FCB 30, 30,105,135,145,150,155,160,155,165,165,175,185,200,190,210,220 ; 2200
FCB 30, 30,105,135,145,150,155,160,155,165,165,175,185,200,190,210,220 ; 2400
FCB 30, 30,105,135,150,150,160,165,160,165,170,175,185,200,200,220,220 ; 2800
FCB 30, 30,105,135,150,150,160,165,165,170,175,175,185,200,200,220,220 ; 3200
FCB 30, 30,105,135,150,150,165,165,165,175,175,175,190,200,200,220,220 ; 3600
FCB 30, 30,105,135,150,150,165,165,165,175,175,175,190,200,200,220,220 ; 4000
FCB 50, 60,105,135,150,150,165,165,165,175,175,175,190,200,200,220,220 ; 4400
FCB 50, 60,105,135,150,150,165,165,160,175,175,175,190,200,200,220,220 ; 4800
I'd show you the AE stuff, but then I'd have to put contracts out on ya,,,,,,,
This is all from what I've found to work for me.
Your results, and tables will be different.
Educational purposes only
Not to be attempted without adult supervision, yada yada
HTH
