Mar 29, 2014 #1 B BOP4ever Member Joined Jul 6, 2007 Messages 892 I took a picture of the Gap between the Nitto 275/50/15 and the gram rail whole car was on the lift today . I think it'd going to be ok .
Mar 29, 2014 #2 M missin' 2 Member Joined Jan 17, 2006 Messages 299 You might get some rubbing, depending on how stout your rear end bushings are and the slop on the mounts. Just don't give her the beans when you are turning, or you might shred a tire like I did. Posted from the TurboBuick.Com mobile app
Mar 30, 2014 #3 H HUMBLE-U2 Well-Known Member Joined Feb 6, 2006 Messages 1,347 install air bags and you will be fine.
Mar 30, 2014 #4 B BOP4ever Member Joined Jul 6, 2007 Messages 892 Putting a hell wig rear bar in instead hoping to avoid the air bag hassle .
Mar 30, 2014 #5 B BOP4ever Member Joined Jul 6, 2007 Messages 892 There is some sort of plug with letters stamped in it in the frame at the top of the tire on the passenger side. I think it's plastic. Anyone else have this or remove it ? I'll take a picture tomorrow . It's the closes spot maybe1/4 to 5/16 inch. I
Mar 30, 2014 #6 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 That's a tag put on the frame after manufacture. I've seen it on just about every G-body I've looked at.
